Document ID# 1866259
2007 Chevrolet Tahoe - 4WD
Subject: Information on Noise from Navigation Radio - Normal Operating Characteristics #06-08-44-034 - (10/10/2006)
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
Some customers may comment that there is unusual or unwanted noise coming from the navigation radio. This noise has been described as a fan sound or hearing a disc spinning.
Source of fan sound -- It is normal for the radio fan to run when the vehicle is turned on and for up to three minutes after the vehicle has been turned off and the driver's door has been opened or closed.
Disc spinning sound -- This is a normal operational sound. This is caused by the map disc spinning behind the tilt screen. It is a normal operation after the RKE is used to unlock the vehicle or when the driver's door has been opened. This noise will also be heard during vehicle operation and up to three minutes after the vehicle has been turned off and driver's door has been opened and closed.
Do not replace the radio as the described conditions are normal operating characteristics.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
