nramo
Water started coming into my 2015 Tahoe, at first I thought the drains were backed up for the sunroof but after testing it no leaks were detected. I tested the shark fin antenna and sure enough water was leaking into the vehicle. I opened up the corner of the overhead cover and was able to reach in to unscrew the antenna. I unscrewed the antenna and it looks like the sun baked the plastic cover and the back screws became loose enough to let water in. The inside is destroyed by corrosion. After seeing that a replacement antenna costs almost $200 I just put it back together and tightened it better to the vehicle. No leaks now that it's tighter.
My big issue is that the dealer replaced this antenna sometime in 2016 and I'm disappointed that it is already gone bad.
If GPS or Satellite radio is not working, the antenna is the issue. Has anyone else had this issue?
