NewtoTahoe
- Mar 1, 2007
Took my 07 Tahoe in for an oil change and asked them to check the rear end since I was hearing some strange noises coming from it. First they pulled the plug and it had quite abit of steel shavings on it so they pulled the cover any my ring gear and pinion are showing significant wear and the back lash is way out of spec. Has anyone else had any similar problems? This should be covered under the warranty right?
