Rearview mirror "ICE"
Gambler
Baltimore
I started up my tahoe after lunch and it was snowing. I looked at the mirror to see the temperature and it said 32deg then switched and said ICE, then toggled back and forth a few times and stayed on 32. Has anybody seen this before? Is it just a warning for possible icy conditions, or is there more to it? Strangely enough during my trip to michigan which was mostly well below freezing, I never saw this message.
High4
It's just a warning. Iv'e seen the same thing on Cadillacs and a Lincoln.
LAP TOP GAMER
Mine did it when it was 36* out as it just lets you know that icy road conditions are possible.
ha ha, yours are all dumb then :lol:
mine only showed ice when i was driving on ice, whether it was 20 degrees, or 36, if there was black ice on the road it said ice, if the roads were dry it said the temp and thats it. :cool2:
MCF34
Please explain...
How it would sense actual ice on the road?
what i mean is when i turned on the car, if it was dry and no snow or ice on the ground (it could be 32 degrees) it would not flash, but when i went up to illinois where there was snow all over the place and in rural areas with not a real good salt patrol, it would flash ice, it did not flash when i was driving, just when i started up, but it knew when there was water on the road. :yesnod:
Gambler
Baltimore
That is basically what I am asking, does it have some sort of humidity or barometric sensor somewhere?
i think mine is broken. :skep:
it just said ice for 67 degrees. so what i think was happening with mine is it was not adjusting to the temp right.
from my other exprence with gm's ice thing, it just warns of possable ice when its below a certain temp.
Hardin Thicke
It's nothing more than a brief warning that outside temperature is approaching the freezing point of water. It's linked strictly to the outside temperature probe.
OStateFlyer
Tulsa
+1
It behaves that way in all the so-equipped GM vehicles I own, have owned and driven. I recall seeing it in all of them at about 34F.
Tahoe07
PA
It will only flash the "ICE" for a brief time when you first start up.
I'd venture that most of you just never looked up when it was on. It will be there when the conditions are right..
why is the tahoe/yukon the only one that says ice on the mirror. almost every other gm vehicle warns it on the DIC. :cryin:
Tahoe07
PA
Our thermometer is there so it kinda makes sense. If I'm at all concerned I will be checking thermo anyway.
OStateFlyer
Tulsa
+1
It will also show up if the temperature falls as you are driving, i.e. pull out of the toasty 55F garage into the 25F weather, or a good cold front blows through, and it will display 'ICE' as the temperature falls through about 34F.
fco_gonzo
Both of my cars (tahoe and the XXXterra) have done it. But the temp was to be around 30 or so.
uofmz71
i had a 98 hoe and it flashed ICE... so its been around awhile
beach109
Yes. We got used to the message often while intermittently driving wherever when it was cold, got colder than it was, etc. in the low 30's or lower, in both our '02 Avalanche and '04 Suburban.
It's basically just temperature sourced, and has been around in many GM's for a LONG time. Nice little detail, I've always thought.
