Removing the center console "box"
genestoy
Phoenix, AZ
Does anyone know how to remove the black plastic box in the center console where the cupholders are on the 2007 Yukon?
Thanks for any help
Gettreal
All you need to do is use a flat screwdriver.... ( I prefer to use a thin plastic spatula to avoid scratching) and pry it up.. it comes up pretty easy.
Gettreal
how much room are you looking for? When I took mine out to run the wires for my dvd players I actually had to tuck in a control unit, and there was plenty of room for that.
genestoy
Phoenix, AZ
I was hoping for about 6 or 7 inches to mount a small cb straight down that is about 4" wide 2" deep and 6"-7" long.
Gettreal
Not sure you will get all of that....trying to visualize it...well, good thing is...within a minute you can find out ...hehe
Gettreal
1st pic...shows where you need to pry up....it literally will pop up
2nd Pic... the blue area is where the space goes down. Quick measurement shows about 5inches or so..
3rd pic shows the interface I have in there
genestoy
Phoenix, AZ
Gettreal,
Thanks a bunch! That really helps a lot. I think I will be able to make this work. :)
genestoy
Phoenix, AZ
The mod for the cb worked out great. Not only was there room enough but at the bottom there were two bolts mounted/welded into the floor pointing straight up that I was able to use to bolt the cb bracket onto that I made! That console is real easy to get wires into and out of also!
