replace 2nd row bucket seats with bench?
Discussion in 'General Tahoe/Yukon/Escalade Discussion Forum' started by chadwick02, Feb 6, 2008.
  1. chadwick02
    chadwick02 Full Access Member
    92
    Jan 22, 2008
    Does anyone know if the 2nd row bucket sets can be replaced with a 2nd row bench seat in a 07 tahoe? And what is involved in the swap? I have finally found the right truck for me, except that its got bucket seats and I NEED a bench seat in the 2nd row. I would think that the mounting brackets would be the same for either configuration, but I need to know for sure.
    Thanks everyone,
    Chad
  2. uofmz71
    uofmz71 Full Access Member
    167
    Oct 16, 2007
    i believe they have the same bracket. why do you NEED it so badly? just curious...
  3. sdoo25
    sdoo25 New Member
    35
    Dec 1, 2007
    Tampa, FL
    I looked at doing this as well and I'll let you know what I gathered from various forums. To swap you need to acquire the following from the same wheelbase vehicle (tahoe to tahoe, not suburban to tahoe):
    bench seat
    brackets for bench seat
    plastic (?) panels that go on top of brackets
    From what I've read and seen in pictures and seen at the dealer, the bench seat has an extra bracket towards the middle of the floor to secure it to the vehicle. Also, the covering panels are different. You aren't able to simply find a bench seat and do the swap. Also, people have assumed that the mounting points for the additional bracket are present on bucket equipped vehicles, you would need to remove the panels and maybe some of the carpeting to gain access and secure the new bracket to the vehicle floor. I haven't seen confirmation of this though nor have I read of anybody actually completing this switch.
    I don't know if you could find a bench from a yukon and put it into a tahoe, it seems like it would work (provided it isn't from a yukon xl), but no one has confirmed.
    I hope this helps. The consesus is that this could be done but haven't seen it done yet.
    Good luck and keep us updated!
    Tom
  4. StL07Tahoe
    StL07Tahoe New Member
    18
    Jan 24, 2008
    We chose a 2nd row bench for the pure fact that it is easier to fit three people in the second row bench than in the 3rd row bench. It makes it more comfortable for all having a bench rather than buckets.
  5. 07LTZ4x4
    07LTZ4x4 New Member
    5
    Feb 7, 2008
    Orlando, FL.
    I don't know if it can be done or not but I have the second row bench and would love to trade for buckets. Providing it can be done fairly easily.
  6. chadwick02
    92
    Jan 22, 2008
    :iagree:
    I plan on taking out the 3rd row seats most of the time, and only using them 2 or 3 times a year. I will need the extra space in the back for stuff and tools (believe it or not, I will be using this as a "truck"). So, with no 3rd row, and only bucket sets in the 2nd row it only seats 4 people, which is not good enough for my situation. In addition, I like the way the bench "separates" the passenger area from the "trunk" of the vehicle. It provides a visual, and a physical barrier between passengers and all my junk that will be in the back at any given time.
  7. chadwick02
    92
    Jan 22, 2008
    What color and material are your seats?
  8. 07LTZ4x4
    07LTZ4x4 New Member
    5
    Feb 7, 2008
    Orlando, FL.
    Tan
  9. chadwick02
    92
    Jan 22, 2008
    Tan is no good. I want the dark ebony color.
  10. gilson5
    gilson5 New Member
    Sep 6, 2014
    seat swap
    NEWBIE question
    I have a 10 ltz with heated pwr folding bucket
    I want to replace with bench, can I get a pwr and heated seat? Anyone know the part #
    Thanks in advance
  11. edfatt
    edfatt New Member
    11
    Aug 16, 2013
    Kansas City, MO
    I have a 2010 tahoe LTZ with ebony leather, heated, power folding, bucket seats I would love to trade for same options bench. I'm in KC area.
  12. Blancher08
    Blancher08 New Member
    4
    May 3, 2014
    Hey I don't know if this will help you, but I replaced my 05 Denali XL (heated seats) with heated buckets. It's just 8 bolts (2 on the outer bench 4 in the middle and 2 on the other outer), as well as the male/female connector for the heated seat components. I did it by myself, and it only took about 2 hours or so; the bulk of your time will be getting the seats. Unless you have help they're pretty heavy. If you look underneath the seats you will see the bolts. It's a direct bolt up without any modifications. Had another buddy that took the bench seats that I took out and put them into his blue crystal XL because he needed an 8 seat configuration because he was driving to Florida. Just my .02.
  13. edfatt
    edfatt New Member
    11
    Aug 16, 2013
    Kansas City, MO
    I appreciate the info. I have read the same, the problem I'm having is that everyone has what I have (buckets) in the 07-14 or they have a bench that doesn't have the same options. The leather ebony heated electric folding bench seems pretty rare and hard to find. I have two very small children where both of their car seats are turned backwards so in order to use the 3rd row some either has to climbing and over the 3rd row or in the through the front doors and over the console.
  14. Blancher08
    4
    May 3, 2014
    I got my seats from the Pickapart place around the corner from my house. I was hunting for about 2 months and I finally got a phone call that said they were in. Cost was about 220, but the seats were exact matches. I have 2 front facing car seats...we actually put the car seats in the 3rd row and fold the 2nd row seats up. Feels like it's a bit more spacious like that.
  15. bluepit36
    bluepit36 New Member
    Mar 12, 2011
    Yes. Just did my 08 Tahoe from buckets to 60/40 split bench. The 60/40 drops right in to your existing mounts. I thought there would be an extra mount but there is not. The 60 portion base overlaps the 40. A total of eight 18mm hex nuts and two 13mm hex nuts for the two inner bolts where the 60/40 join together. I am working on getting the single piece seat mount cover since the captains seat mount covers don't work.
    Note: Make sure the seat is out of a 07-14 Tahoe/Yukon. Suburban/Yukon XL will not work since their floor pan for the 2nd row is flat at the rear mounts of the seats. Tahoe/Yukon has a raised mounting surface at the rear.
  16. jaelliott
    jaelliott New Member
    5
    Aug 17, 2015
    Looking to do this swap myself. IT is actually this post that made me join the forums. Have an 08 Tahoe LTZ with second row bucket seats.
    At the hospital now waiting on our third child, first girl, to be born. We realized that have a 4 and 2 year old in the third row is very inconvenient. Best solution is a bench conversion. Otherwise we'll be looking to buy new and that is unfavorable as we own our tahoe and dislike payments.
  17. Cphobe
    Cphobe New Member
    Nov 12, 2015
    2nd row success?
    I wanna do the same thing? Did you have any success?
  18. Murder n Mayhem
    Murder n Mayhem New Member
    30
    Oct 18, 2015
    Washington St.
    If woulda fit I would trade my great condition '03 Tahoes pewter/shale leather (shade of gray) 2nd row bench (with all brackets hardware & fold down panels) for 2nd row leather buckets (with all brackets & hardware) in a heartbeat.
    Limits storage with buckets over bench but be easier for kids & dog to get into third row seats\rear.
  19. factoryride
    factoryride New Member
    5
    Jan 20, 2014
    Have a 2010 Tahoe with a titanium leather bench that I am looking to trade for 2 second row titanium leather captains chairs. Just in case anyone wants to swap. KC area.
  20. Cabinet10W
    Cabinet10W New Member
    Dec 16, 2015
    2011 2nd row bench
    I need a 2nd row bench for my 2011 Tahoe, I found a new cloth bench from a 2015 tahoe that the guy swears will fit. Before I drive out to get the bench I want to double check that it will fit over the existing bolts in the truck. Does anyone know if it will fit or where I can get this info without calling my local dealer?
    Thank you.
