Looking to convert your failing air suspension to a more reliable coil spring setup? Arnott offers a low-cost alternative to air suspension system replacements that allow you to maintain normal driving characteristics and save on repairs!
Their Air to Coil Spring Conversion Kit features simple, worry-free metal coil springs that require no serious modifications. It replaces your air ride parts, including your air springs, with traditional steel coil springs and passive shocks.
Arnott® - Air to Coil Spring Conversion Kit
- Set coil springs and shock absorbers designed to bolt directly in place of existing air springs with no modifications necessary to your vehicle
- Eliminate the worry of failing air suspension parts which can leave you stranded with extremely costly repair bills
- Black powder coat provides a durable finish that is resistant to chips, corrosion, and paint flaking
- Coil springs feature a variable spring rate that provides a softer, more comfortable ride that progresses to a firmer ride during aggressive driving or when vehicle load increases
- The kit also includes a pair of OE equivalent replacement shocks
- Conversion kit does not come with any provisions to bypass and disable suspension warning lights once original equipment is removed
https://www.carid.com/arnott/
Enjoy safe, comfortable and trouble-free driving with Arnott Air to Coil Conversion Kit!
