Reprogramming Key Fobs
Murder n Mayhem
Washington St.
Key Fob Reprogram
1. Close all vehicle doors.
2. Insert ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch on the*door*panel.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. (within 5 seconds).
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approx. 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the*keyless*entry*transmitter mode.
9. Operate the transmitter functions in order to verify correct system operation.
Murder n Mayhem
Washington St.
Programming Instructions for 2007 +
Procedure #1
Vehicle must have a driver information center. Vehicles equipped with driver information center will have button on the steering wheel with an "i" symbol .
1. Insert key into ignition and turn it to the on position. Do no start the car.
2. Press the Information button until Relearn Remote Key is displayed.
3. Press the set/reset button (will have checkmark on button) until Remote Key Learning Active is displayed.
4. Press and hold the Lock and Unlock button until vehicle chimes twice this signals successful programming. Repeat step 4 for any additional new and existing remotes so they will all work on this vehicle.
5. Turn key to the off position which will exit programming mode.
Procedure #2
Vehicles without the information center
1. Insert key into the ignition and turn it to the On position. Do not start the car.
2. Press the trip odometer reset button until Relearn Remote Key is displayed.
3. Hold the trip odometer reset button until Remote Key Learning Active is displayed
4. Hold the lock and unlock buttons on the remote being programmed until the vehicle chimes. This signals successful programming. Repeat step 4 for any additional new and existing remotes so they will all work on this vehicle.
****IF ANY OF YOUR REMOTES STOP WORKING AFTER PROGRAMMING SEE STEP 4 YOU MUST PROGRAM ALL REMOTES IN STEP 4!
