hntrgrn04
Member
So I had problems starting the truck all the time, once got moving would not want to take off and when it did it would hesetate. did some reading and was suggested to replace fuel pressure regulator. So I did still had same problem, then while ideling in the drive way truck shut off and won't restart. changed fuel filter, still no luck. someone told me that the fuel pump was not putting out enough pressure to deliver fuel to motor, if this is true do I need to change fuel pump.....
