MarkD51
Hi all,
About a month ago, was doing some detailing on the fender wells, cleaning up suspension components, grease job, etc on my 1997 4WD 4DR Tahoe.
Well, to get to the point, just out of curiosity, decided to take tape measure to see how front ride height looked. I had found that my passenger side was more than 3/4" lower than the driver's side. (Measured at the Fender Lip)
Upon inspection, I noted that the Torsion Bar Key Bolt on the passenger side looked to be much further screwed out than the driver's side by a good 5-6 threads.
Since I am the original owner, and can recall way back looking at these when the truck was new, I seem to remember both adjustment bolts showing an equal amount of threads.
So, out came floor jack, some penetrating spray, the appropriate Socket, and 1/2" breaker bar, and began to adjust the passenger side only.
I did not touch the driver's side adjustment bolt at all. My reasoning, was with some common sense, that I've never seen any bolt in my lifetime somehow "tighten itself", only ever loosen.
I started with a full turn, then two, and began to see the height was coming up, but still no cigar. Each time, I lowered the jack, bounced on the front end a bit so the suspension would settle. I was getting closer to matching.
As I began to get closer, to within a 1/4" difference, the passenger side still a tiny bit lower, I took the truck for about a 1-1/2 mile ride, letting the suspension jostle around a bit, then back on the concrete slab to check again, and again. I probably took the truck for another 4-5 little rides as I got closer and closer to matching height.
I did take note of exact measurements, I was writing them down each time I made an adjustment, and one funny thing I noted, that although I did not adjust-touch the driver's side Bolt, the driver's side seemed to ever so slightly increase in height as well by perhaps 3/16". Is this possible?
Before I began these adjustments, I had sort of noted that the truck's ride seemed like crap. Lots of bouncing, a funny ride, steering seemed shoddy in comparison to the after adjustments.
After about an hour's time, just taking my time, with no rush, I seemed to have gotten a virtual perfect match in height on both sides. If there's still a difference, that difference might be as little as 1/16" variance.
Betting that by the time I got done, I figure I did close to 5-1/2 to 6 full tightening turns of the Passenger Torsion Bar Key Adjustment Screw. Both now appear to match quite closely as to how many threads now show.
Again, after I completed this adjustment, the truck seemed to ride, and handle much better. Instead of what commonly happens, that the ride is said to become harsher, my ride handling, and steering got much better.
Wheel alignment, although none was done after, seems great, the truck tracks like it's on rails, no pull, no funny steer, truck feels great, rides great, looks better, no odd looking camber of the wheels-tires.
As I close, and wish to garner comments, does it sound like I did all OK?
Since these are old tires, I'm not going to worry about them at this point, but when the time perhaps comes that I wish to throw a nice new set of 20's with perhaps 275/55-20 tires, I will of course seriously consider an alignment to get the longest life from the tires.
I'll include a few recent pics so you folks can see how the truck's stance looks.
Keep in mind as well, that I do have Firestone Ride Rite Air Bags on the back, and that I keep them inflated at 40psi at all times, even when not carrying any loads.
Thanks folks, Mark
Thanks folks, Mark
