Transmission not selecting Reverse
Blue
Hi Guys,
I'm form Europe, Belgium and there isn't alot of experience with the Tahoe's so I thought I would ask here.
I have a 2001 5.3 Tahoe and I use as a daily driver.
But I also tow alot of cars with my trailer.
(+-6600 pounds/3000kg of weight that's trailer incl car)
(it has normal suspension, no airride, but selectable 4WD)
Now I usually don't put it into TOW mode and always use 2wd drive.
But today my dad went out with the tahoe to pickup a car from a customer,
it was in a hilly route so what he did was press the "TOW" button each time there was a hill in front, but only when not giving it any throttle, once selected he pressed the throttle.
after 4h of driving (2h unloaded to the client, 2h back with the trailer and car on top) he arrived at our home.
The traffice light before he noticed the tahoe wouldn't pull as good anymore,
when he tried reversing onto the lot it wouldn't select Reverse anymore!
and the translight came on.
Now....our garage wants to take it apart tomorrow and bring it to a transmisson workshop
1) is that indeed the best idea?
2) what do i need to tell them?
(remember I do tow alot of weight alot of time)
As i'm unaware of the transshop having alot of knowlodge with this type of transmission i would like to have some information to give them before they start to rebuild it.
thanks!
dye4metal
Sarasota, Fl
for the transmission to not select reverse after the trip seems like coincidence.
how many miles are on the truck?? i would let a tranny shop check it out, the tranny is a 4l60e for your reference. usually the reverse gear will have nothing to do with the forward speeds
Tofast4U
I just had my rebuilt and the Tranny guy I went to said that is a very common issues with the 4l60E tranny.You Broke the Cage where all the clutch plates sit.
