TN Tahoe
I can't say enough about the new two-way remote. Works great and it really has some nice range to it. The size is just a bit thicker then the original remote but close to the same size as the original in diameter. The unit available for my Tahoe controls the following:
1. Lock and unlock doors and status
2. Opens rear glass
3. Auto start and show remaining time left before shut off
4. Fuel level
5. Tire Pressure
6. Mileage on vehicle
7. Radio control (this works for if you have the Tahoe running you can use the remote to control the stations listed in your favorites)
Note: Works well with your memory package.
Very Cool.
I spoke with the Tech when it was installed and also looked at the kit in the parts department before the install. The only thing added into the Tahoe is a small module and antenna. The module is about 3" square and it replaces the existing one located in the back cargo area of the Tahoe under the rear glass on the driver side. I also had the factory NAV unit installed while I was there. I've posted a picture of it as well. I have spent most of the weekend in the garage playing..LOL
2. Opens rear glass
4. Fuel level
5. Tire Pressure
Very Cool.
