Unique Issue :help:
GreaseMonkeyLSX
Alright guys, im having an strange issue with my truck. Previous owner put in a Viper alarm which seemed to work "OK" but recently when i disarm and attempt to unlock it unlocks all 4 doors but when i arm or lock the truck it only locks the drivers door.:whymewhyme: if i hit the lock button on the door panel it also does the same unlocks all but only locks driver door WTFFFFFFFF
Anyone had this issue
FYI i checked all fuses all are good
Treehan77
Did you reprogram the progressive unlock in the DIC? Lots of cars let you unlock the drivers door only first, then all doors. Maybe your alarm is set up to just click once, and the truck needs to be set to unlock all doors in one click instead.
GreaseMonkeyLSX
Man i dont even know what model alarm or even how to do that i know its a viper just because thats what it says on the remote I REALLY HATE ALARMS
Treehan77
On the trucks driver information center guy, not the alarm. Read the manual for your truck
Treehan77
perhaps you should include relevant information like that in your post guy
GreaseMonkeyLSX
perhaps you should ask before you assume just as i assume you dont have a solution to my issue good day to you sir or shall i say "GUY"
Treehan77
well you'll need to find out what alarm you have, guy. theres a thing called Priority Unlock for vipers, guy. or try hitting the button a few times really quickly to see if it needs a double pulse to unlock them all, guy. easiest thing would be to take it to a Viper dealer who has a BitWriter to check all the settings, guy.
