XM sound quality
Discussion in 'Satellite Radio XM / SIRIUS' started by Mad Dawg, Apr 18, 2008.
  1. Mad Dawg
    Mad Dawg Full Access Member
    98
    Feb 6, 2008
    Raleigh, NC
    Is just me or am I having problems with XM on my 07 Tahoe. The sound quality coming from XM absolutely stinks as compared to regular radio, even more so as compared to using the CD or Ipod inputs. To me the sound quality is similar to internal computer speakers - very tinny. Even after tinkering with the EQ settings, there is no to very little improvement. I have the non-nav/non-Bose radio in my Tahoe. I had an overnight loaner from the dealership which had the nav/Bose unit and the sound quality was great from XM. Do I need new speakers?? A new XM receiver?? A sound processor that "cleans" up the output signals from the headunit?? Please help!!
    Any and all suggestions are welcome.
  2. carguy
    carguy New Member
    Jun 16, 2008
    I have a 2007 Suburban LTZ with the NAV unit and the Bose Premium system. My XM is terrible too. Tinny and low-level. Occasionally I also hear low-level static interference on the XM.
    Here is what I have surmised. The Denso unit is a lousy design. It appears that the XM tuner does not go into a normal audio input like the CD or AM/FM channels. It sounds like the XM is actually coming over an FM/modulator and it overlaying a weak FM channel. In areas where there is a local FM channel, the XM signal exhibits background noise. I believe the tire pressure wireless transmitters also contribute to the bad XM sound.
    The reason I spent extra for the Premium package is so I would not have to have an after-market XM unit with an FM modulator. Even a hard-wired type of modulator is marginally better. I wanted the best sound quality so I went with an integrated unit.
    It is unbelievable in this day and age, that a $50K+ vehicle with a PREMIUM sound system would sound so bad.
    The only fix I can think of is to go to an external XM unit and use an AUX input. I have a Coastal Electronics GMX-320 Lockpick which provides for two additional audio inputs. You could go in through one of those for a clean look. You would still have an extra XM tuner hanging around though. :cryin:
  3. LAP TOP GAMER
    LAP TOP GAMER Full Access Member
    4,197
    Sep 2, 2006
    I have noticed the i pod sounds better, and you have to consider signals bounced off a satellite are going to lose some sound quality, that is one of the down sides of satellite radio.
  4. carguy
    carguy New Member
    Jun 16, 2008
    The distance to an XM satellite has no bearing on my problem. I know how compressed XM is.
    I can take an XM Roady and take the output and plug it straight into the AUX input of my GM NAV unit. It sounds just as good as the CD or AM or XM.
    The problem that I am having, as well as others, is the way GM is connecting their internal XM tuner to the head unit. They are obviously using an internal FM modulator which is prone to noise injected by nearby FM radio stations and the tire pressure transmitters.
    I may end up using the Roady XM tuner and give up on the internal XM unit .....
  5. wilb3
    wilb3 Full Access Member
    59
    Jul 30, 2006
    MiddleCountryUSA
    I noticed a decrease in my XM sound quality just recently. CD/radio are fine. I may look into reconfiguring the input. Thanks for the tips.
  6. LAP TOP GAMER
    4,197
    Sep 2, 2006
    XM sounds ok, but CD's and the i pod sound better.
