Yukon XL Idle Surge
Discussion in 'Suburban / Yukon XL / Escalade ESV' started by Chris Till, Jan 6, 2014.
  1. Chris Till
    Chris Till New Member
    Jan 6, 2014
    I have an 04 Yukon XL. About a month ago, check engine light came on. Took to my mechanic. Said it was a lean fuel code and to put some additive into gas tank. I did this and it seemed to work. This weekend, it got very cold where I live and engine started to idle rough. RPM's and engine would surge while in park or at a stop light. Took to mechanic today. Computer said MAF sensor was bad. Had it replaced along with fuel filter. Seemed to run normal again while at the shop. Once I got it home, I put it into park and the engine started to surge again while in idle. Although it was not as profound as before, it was still surging. Any suggestions on what to look for next? Thanks for your help and have a blessed week.
  2. rockenthebowtie
    rockenthebowtie Full Access Member
    694
    Oct 6, 2013
    Any time I want
    Try cleaning the throttle body assy.. if that doesnt help it might be the upper intake manifold gaskets
  3. laredo1307
    laredo1307 New Member
    6
    Dec 17, 2013
    Houston
    Check the intake gasket by spraying some brake cleaner around where the intake gasket is. If the engine stumbles then you probably have a leak.
  4. TeamTahoe
    TeamTahoe New Member
    6
    Dec 20, 2018
    NorCal
    I have a similar question.
    I would like to start a new thread.
    How do I go to start a new thread?
