Are the Z71 springs stiffer or do they ride higher than the stock ones? Are there aftermarket rear coils and front torsion bars that (with a levelling kit) will give me slightly higher load capacity with 750# or so on-board?
With the current (stock) setup the rear is visibly lower. Would like to get back to normal ride height when loaded as above and 2-3" higher when empty... Note, obviously I don't have the auto levelling option.
Or would in-coil air bags be the best choice...
