03 yukon 5.3 trans drain and fill???How many quarts??
JennaBear
CA
10-14 quarts...your manuak should tell you the exact amount.
Nappers
Yreka, CA
A full drain? I've gotten about 6-8 qts on just a pan and filter pull. Do it every year. I put 5qts in and warm it up and go from there, easier to add then to take out :D
Aaron
MikeyAces
eastpointe, michigan
Aaron
Ya a full drain.I want to start running amsoil and I want all the stuff out. I want to drain the converter also.
Nappers
Yreka, CA
I've never done a full drain, some of the older Fords had a drain plug on the converter but with the GM trannies, you may have to go to a tranny shop to flush it out, don't do a backward flush, read/heard too many problems when that happens. Hopefully someone else chimes in on how to dump the convertor.....
