02TAHOELT
Does anyone have a 2/3 McGaughy's with the Autoride system? My question is, do you have to bend the linkage rods in the rear for the sensors? And where can i pick up a set of Bump Stops to replace the OEM one's
Had to build some on mine with the 3/5, used some grade 8 bolts the same diameter and cut them, then proceeded to thread them to the same pitch as the oem links and voila no more lift. I fvcked around with the links for about an hour until it sat level once the compressor kicked on, best of luck.
