IronMan4Real
99 Hoe, under heavy rainfal there is about 2 table spoons or less of water accumlating on the passenger front floor mat.
I did some reading and have inspected the following
I removed the cowl, inspected for build up of leaves and debris and even vacuumed it out. Resealed properly.
I traced under the dash and its dripping from a cable covered in foam. If you pull the glovebox it comes from there.
The windshield is original, no accident,never been painted.
Door rubbers mint and I have used the GM silicone stuff on it to swell the rubbers. Its not coming from the door. It drips from under dash. Its not alot. But I am anal and want to fix it right. I can not see exactly where its coming from and at present i have a broken rib on the mend so I am having a tough time laying under the dash.
I checked all the simple stuff. Its from Florida so its 100% rust free. The rubber floor at is catching all of it so its not rotting the floor.
I can not find the drain hose for the ac. When I worked at the dealer, we would pull the house and usually it would be gummed up.
If anyone has photos of where it is I would love to try that next.
I prefer real photos vs schematic photos.
Many kind thank you
Many kind thank you
