GMCYukalade
Ok, so.. i have a 99 Yukon with rear-air - My front air is warm.. - i have cleaned the Evap core - still warm - charged the system - still warm - now, i went to check it, and it was back down to 15psi (after 3 weeks of leaving it alone) so i know it has a slow leak - - but that isn't all - i have a question about why it isn't cold - i know even if it has 35psi in it, it should be cold - right now it is at 45 (max) - now, the Compressor will kick on, and then run for a couple seconds and go off - i don't know if this is normal - there is a sensor on it - do you think that sensor is failing? - also - the sensor on the thing near the cab.. what is it for? - i don't know i guess i'm askin what all i need to trouble-shoot for the air
- Edit -
Also, when i pulled the blower motor out, there is a metal clip on one of the fins, that looks kinda like a staple, but it was bent and put on there.. i think - is that factory? like a balance or something?
- Edit -
