Has anyone added OE Fog Lights to the 2015 LT. If so, where is the fog lamp relay located. The under hood fuse block already has the fog light fuse in place from the factory, but I can't seem the find the relay.
Elsewhere I've read of guys that have purchased the lamps and brackets and installed the lamps in the bumper, but that's as far as they have gotten. Looks like you can get the fog-lamp capable light switch - but the question is related to the wiring harness that would connect the lights - from what I read it appears this may also connect the front bumper sensor options and it is unclear if just the fogs could be made to work without the rest.... regardless it seems the BCM would have to be (re)programmed to tell the vehicle that it has fogs.....
interested in what others find as I'd like to add OE fogs to our 2015 Suburban LT as well
I just installed the "OEM" fog lights
[2015-2016 Chevy Suburban FL-CTAH15-C Tahoe OEM Style Replacement Fog Lights Pair - 85.99]
and they came with a relay. I hooked them up in the fuse box with a piggyback fuse holder on the parking lights. The harness also came with an on/off switch but I can't find out where to get it thru the firewall easily. Hence, I have left them on so they are on when you have the lights on.
