AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL)
clkelley
Moderator
Galax, Virginia
CLICK HERE For Pricing & Ordering Information
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
30-Gallon Drum
55-Gallon Drum
AMSOIL Synthetic Lubricants Incorporated, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972 and continue to be the industry leader in the testing and development of the highest quality synthetic lubricants for today's demanding and ever changing automotive applications. Trust the extensive experience of AMSOIL, the First in Synthetics®, to do the best job protecting your engine.
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) delivers extraordinary lubrication in all types of automotive gasoline engines. By combining industry-premier synthetic technology with AMSOIL premium additives, Signature Series Synthetic Motor Oil exceeds the higher performance demands of modern engines. It withstands the stress of higher horsepower, higher heat and complicated emissions control systems. Signature Series Synthetic Motor Oil is engineered to outperform competitive conventional and synthetic motor oils. It delivers long-lasting performance and protection.
Extends Drain Intervals
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) can extend drain intervals far beyond those recommended for conventional oils. Its unique synthetic formulation and long-drain additive system are inherently stable to resist oxidation and neutralize acids over longer periods. Signature Series Synthetic Motor Oil is designed to deliver the best possible engine protection, cleanliness and performance over extended drain intervals. It reduces vehicle maintenance and waste oil disposal costs.
Maximizes Fuel Economy
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) is designed to maximize energy efficiency for improved fuel economy. Unlike conventional oils, its uniform molecular structure helps it flow more freely and reduce friction between metal surfaces. Anti-friction additives are included to further improve energy efficiency.
Reduces Engine Wear
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) provides outstanding anti-wear protection. It has excellent viscosity film strength to separate metal surfaces and robust anti-wear additives to further reduce wear in metal-to-metal contact regions for improved engine life.
Reduces Oil Consumption and Emissions
Volatility (burn-off) occurs when oil gets hot, causing high oil consumption and emissions. AMSOIL Signature Series Synthetic Motor Oil exhibits an extremely low volatility rate; it controls volatility-related oil consumption and emissions.
Excels in Extreme Temperatures
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) resists thermal (heat) breakdown better than conventional oils. It is heavily fortified with detergent and dispersant additives to help prevent sludge deposits and keep engines clean. And unlike conventional oils, Signature Series Synthetic Motor Oil contains no wax, staying fluid in the coldest winter temperatures for easier starting, improved oil flow and reduced bearing wear.
APPLICATIONS
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) is excellent for use in all types of gasoline-fueled vehicles. It is recommended for all domestic and foreign vehicles requiring any of the listed performance specifications:
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL): API SN (Resource Conserving), SM…; ILSAC GF-5, GF-4…; ACEA A5/B5, A1/B1; Ford WSS-M2C946-A, WSS-M2C929-A; Chrysler MS-6395; GM dexos1™ (supersedes LL-A-025, 6094M and 4718M) Fortified with detergents that exceed dexos1™ sulfated ash specifications.
COMPATIBILITY
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) is compatible with other conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil’s life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL synthetic motor oils.
SERVICE LIFE
AMSOIL Signature Series 100% Full Synthetic 5W-30 Motor Oil (ASL) is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline-fueled vehicles as follows:
• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first.
• Severe Service(4) – Up to 15,000 miles or one year, whichever comes first.
• In all non-gasoline-fueled vehicle applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval.
*OEM – Original Equipment Manufacturer
(1) Engines operating under modified conditions (non-stock) are excluded from extended drain recommendations. Examples include the use of performance computer chips; non-OEM approved exhaust, fuel or air induction systems; and the use of fuels other than those recommended for normal operation by the manufacturer.
(2) Mechanically sound engines are in good working condition and do not, for example, leak or consume excessive amounts of oil, are not worn out, do not overheat, do not leak antifreeze and have properly working emissions control systems. AMSOIL recommends repairing malfunctioning engines prior to the installation of AMSOIL synthetic oils.
(3) Personal vehicles frequently traveling greater than 10 miles (16 km) at a time and not operating under severe service.
(4) Turbo/supercharged engines, commercial or fleet vehicles, excessive idling, vehicles with more than 100,000 miles without prior continuous use of AMSOIL motor oil, daily short-trip driving less than 10 miles (16 km), frequent towing, plowing, hauling or dusty condition driving.
AMSOIL Ea® Full-Flow Oil Filters are designed for extended change intervals. They stop smaller particles, flow more oil and last longer than regular filters. For best performance, use AMSOIL Ea Full-Flow Oil Filters.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). An MSDS is available via the Internet at AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases or upon request at (715) 392-7101. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
For warranty information, visit www.amsoil.com/warranty.aspx.
TYPICAL TECHNICAL PROPERTIES
AMSOIL Signature Series 100% Synthetic 5W-30 Motor Oil (ASL)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
10.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
60.3
Viscosity Index (ASTM D-2270)
166
CCS Viscosity, cP @ (°C) (ASTM D-5293)
4911 (-30)
Flash Point °C (°F) (ASTM D-92)
228 (442)
Fire Point °C (°F) (ASTM D-92)
246 (475)
Pour Point °C (°F) (ASTM D-97)
-51 (-60)
NOACK Volatility, % weight loss (g/100g) (ASTM D-5800)
7.0
High Temperature/High Shear Viscosity
@ 150°C, 1.0 X 10[SUP]6[/SUP] s.[SUP]-1[/SUP]), cP (ASTM D-5481)
3.2
Four-Ball Wear Test @ 40 kgf, 75ºC,
1200 rpm, 1 hr, scar diameter, mm (ASTM D-4172)
0.35
Total Base Number (ASTM D-2896)
12.6
AMSOIL Preferred Customers SAVE up To 25-30%
AMSOIL Dealer, Commercial & Retail Account Opportunities
Contact Us For More Information Or If You Have Questions Now...
Originally Referenced From Here: http://www.syntheticmotorsports.org...-100%-full-synthetic-5w-30-motor-oil-asl.html
blackhawk17
I read your post and I went to the AMSOIL website. I'm interested, but I'd like to have your input. I have a 05 Tahoe that just clicked over 100k. I bought it at 60k, and I don't know what was used prior to my ownership. I've never used AMSOIL before. I'm interested in the SAE 5W-30 Signature Series Synthetic, but I saw a blurb about engines with over 100k that had never used AMSOIL before. So, would the 25,000 mile interval not work for this engine because it's over the 100k mark? I've always been a religious 3,000 mile guy, but I would be interested to try it. So, no oil or filter change for 25k- or do you change the filter more frequently?
clkelley
Moderator
Galax, Virginia
Good evening,
The general rule of thumb for 100K+ engines is if they are in good running order with no visible signs of leaks then you will be fine. The main issue with engines with over 100K is the risk of leaking.
The 25K mile change intervals are achievable with higher mileage engine. For those serious about running the longer intervals, when changing over, to eliminate the "guess-work", I recommend that when they order their oil and filter they also order an used oil analysis test kit. and take a sample of the oil when you would normally change it. The kit linked above if postage prepaid and is simple to use and inexpensive. When you submit the sample, it will tell you about all the contaminants in the oil as well as the oil viscosity and total base number (TBN). The TBN and viscosity are what make sure the oil in lubricating and protecting the engine like it should. TBN and viscosity stability has the most to do with the ability of the oil last for the longer intervals.
The analysis report will also show the levels of wear metals and additive materials. This information can clue you in if there is something going on inside the engine that could lead to a problem. For example, a report that shows high levels of potassium will point to coolant contamination. While a report that shows high levels of copper and aluminum could mean that the engine could have excessive wear to the bearings, cam, etc.
AMSOIL not only offers great oils that are warranted to last as long as they advertise, they also offer ways for the end consumer to make the change in such a way as not to have to trust them on blind faith.
That being said, if you use the links I provide to place an order from the website, become a preferred customer through me or order directly from me personally through email or a phone call; I become your default Dealer representative and therefore your contact with AMSOIL for anything you need.
Let me know if you have further questions.
