Polecat
was reading this, do any of you still use your 'auto' headlights, or just do manual now??
Tips: 1, turn on the engine first, before turn on the HID kit. 2, don't turn the HID on and off frequently. 3, don't install the HID ballasts and igniters near the engine nor anywhere the water can easily get onto. 4, make sure the connectors of the HID kit is tightened to the stock harness. One or both light can't ignite initially. Bulb turns off after the vehicle just starts. Inspection Procedure: You MUST DISABLE Daytime Running Light or "Auto Switch-On" functions before the HID installation, please click here for more information. HID system requires a steady level of battery voltage of at least 12V initially. "Auto Switch-On" and Daytime Running Light functions draws power from the vehicle battery which causes the HID system to fail to initially ignite. If you have Daytime Running Light, disconnect the fuse or wiring of Daytime Running lights only. Please contact your vehicle dealer/manufacturer for more information. If you have "Auto Switch-On" Headlight function, ensure to switch the function to "Manual Switch-On" headlight mode.
**To avoid further damages, always remember to start your vehicle before turn on the HID system.**
