This mod is to make your fog lights turn on automatically when starting the truck. This mod also allows you to keep the fog lights on while you have your high beams activated. You CAN NOT turn the fog lights off, they stay on at all times.
Tools Needed.
- (1) Quick Connector.
- (1) Ring Terminal or Eyelet.
- Short Piece of Wire.
- 7MM Socket.
1) Remove the bottom trim. Do so by un-screwing 2 bolts with your 7MM socket.
2) Locate the middle connector on your Body Control Module. It's right below the steering wheel.
3) Look for a green/white wire located on A7. There will be 2 green/white wires but look for the one that's located on the bottom row and it'll have a number 7 below it.
4) Cut the wire.
5) Then ground the wire that's going into your dash to good ground source. Make sure to not ground the wire that's going into your Body Control Module box.
6) Replace everything as your removed.
I'm sorry if there is another thread about this subject, I tried searching but I could not find anything like this, all I found was the 4 high mod. Let me tell you, the 4 high mod added with this automatic fog lights is AWESOME!
Tools Needed.
- 7MM Socket.
4) Cut the wire.
