any ideas on what you may think caused this? i had to replace #8 cylinder exhaust valve after noticing a horrible misfire. after hooking up scanner and finding out more than one cylinder misfiring. i replaced a bad cap and rotor and spark plugs. still bad misfire. checked with scanner after cap rotor plugs, just cyl. 8 misfire. thus took compression , 0 ! upon removing upper manifold for head removal, found fuel pressure regulator leaking, replaced that as well.
truck runs fine now, but stumped what could have bent the valve. any thoughts.
