Door handle lube?
mlepage
I have a 2000 Yukon SLT. It has four door handles that pull out on a pivot. A few are sticky, stiff. One doesn't really go back in on its own, I have to be sure to push it back in myself. How should I go about lubricating them?
mlepage
No ideas at all? Presumably it's a grease of some sort? Should I be cleaning away the old grease first or something?
speedr1023
CT
i can think of 2 possibilities.
1. WD-40 with the straw on the end and try to shoot some from the outside.
2. Take off the door interior and you should be able to access it from there to lube at will or possibly the assembly has come loose.
