Enjoy superior braking with NRS Galvanized Brake Pads on!
https://www.youtube.com/watch?v=WAkw6_ysdtw
NRS Brakes is the most innovative pads that are designed to improve the safety of your car and extend the service period of your brake components. Recently they've launched a completely new line of Galvanized Brake Pads that feature mechanically attached friction on a galvanized steel backing plate.
The majority of aftermarket brake pads today use steel back-plates that are already susceptible to corrosion and rust. NRS is a process of the surface modification of disc brake backing plates that involves adding a consistent matrix of raised steel hooks that facilitate a mechanical bond between the backing plate and friction materials.
NRS Brakes® - Galvanized Brake Pads
- Corrosion resistance superior to powder coating
- Longer product life: Galvanized steel will outlast the friction material
- Fit and function is improved, reduced returns, noise benefits
- Premium product that matches OE
- Ensures optimal performance over time
- Perfect for harsh environments like braking
- The zinc coating forms its own oxide coating over time, further protecting steel from corrosion
- 100% copper free and asbestos free
- Environmentally friendly, 100% recyclable.
https://www.youtube.com/watch?v=Fzc-Mp8B1F8
NRS Brakes™ | Galvanized Brake Pads — CARiD.com
To avoid becoming part of the brake-failure-accidents statistics, make sure that your brake pads won't let you down - install a set of new NRS Galvanized Brake Pads.
