Front grill swap question...
hmoobsupra
Clovis, CA
I like the looks of the 07 Denali front grills...just wondering how much work is involved in swapping the stock 07 GMC Yukon grills out with these?
Thanks in advance....
gm_geek
Poway CA
first You take bolts off. you going to need 7mm and 10 mm sockets
then You'll need to Release the tabs securing the grille. I use right angle small hook tool to release those tabs
hmoobsupra
Clovis, CA
Thanks GM....I assume the bottom one is very simple as well. Going to order a set tomorrow...:)
gm_geek
Poway CA
don't know what you are going to pay, but I can get you upper and bottom $250 shipped. original 07 Denali Grill
FadedSS
Can I order one from you? I have an 07 yukon that I really want to put denali grille's on...
