Front Right Wobble
bakdrft
Steeringwheel wobbles at a slow speed then corrects itself at higher speeds. I jacked up F/E and was able to wiggle pass front tire, driver side nice a tight. No noise while driving.
CV Axle or Hub?
Im leaning towards hub.
rockenthebowtie
Any time I want
When you checked the right side tire did you grab it at 12 and 6 oclock or 9 and 3 oclock to check hub bearing put hands at 12 and 6 see if its loose to check inner or outter tie rod ends put at 9 and 3
bakdrft
I only checked the 9-3 axis. Ill check the 12-6 axis, If it wobbles all ways that usually means a hub?
bakdrft
Just lifted the Front end and tried the 12-6 test and the wheel hub is the problem. It moves left/right- up and down... Thanks for the Help!
