silvertahoe04
- May 15, 2008
2004 Tahoe
Firestone Destination A/T tires
Truck has 70k miles. Not sure if tires have 70k,
bought truck from private owner a year ago.
The front tires have started to wear on the outside
edge, about 1-1/2 inches inward from shoulder.
Is this due to bad alignment/camber/toe-in/whatever
or tire pressure? The max tire pressure on the tire
sidewalls is 44 psi. The Tahoe door says to use 32 psi.
The tires were all at 32 psi. For now I have raised all
of them to 40 psi.
Has anyone seen this kind of wear? If so, was it
pressure or alignement? If alignment, what had to be
done and what did it cost (could it only be done by the
dealer--I don't trust them very much)?
Thanks.
of them to 40 psi.
Thanks.
