Well, I finally found a Tahoe and pulled the trigger. I found a 98 LT 4 dr 4x4 with posi traction with 124k. The exterior is pretty sharp. There is a minor ding in the rear fender trim and some scratches on the roof. Other than that, it's pretty sharp. The interior is decent. The seams on the front leather seats is split in a couple places and the dash and plastic trim needs a good cleaning with simple green.
There are no visible leaks. I found a little oil on the bottom of the oil pan, but no drips. There was also oil spilled around the spout where it was spilled when the oil was changed. I think it dripped down. It drives great and the only mechanical problem I've noticed is the steering feels a little loose. I don't know the maintenance history so I'm going to take it in and have all the fluids replaced and have a good thorough inspection. Then the fun begins with the modifications. I'll definately be coming back here for some advice and ideas. First things will be cold air intake, flowmaster series 50 and a programmer. Never used a programmer so I'll need a little direction there on which brands you think are better. Oh yeah, I got all this for $3600!!!
