Has any one had front glass problems?
I noticed my front glass fogging after I went through the car wash, and it dosen't go away, so that means the glass has a defect that allows moisture between the glass layers, this means I need a new window.
On your house yes. But the tahoe only has one pane.
are you sure you have tried everything???
in my 06 i drove with a cracked window for weeks and no issues with fogging that were not taken care of by using the defroster, or wipeing the wipers.
DownTownDru
Bloomington, IL
Windshields are basically heat bent two-pane plate glass with a thin latex layer between them to prevent shattering. It is possible that there is a defect in the glass... can you see any distortions in the glass in the area of the fogging?
Auto glass other than the windshield will be tempered single-pane safety glass with no latex layer.
A J
Poe1983
Southern Cal
That sounds strange. I haven't ever had that problem. Keep us posted on this.
Just for clarification (no pun intended) when you say front glass, do you mean your windshield, or one of your front doors???
