Hello All,
I do not have a problem, I have an IMPOSSIBILITY. I purchased my 2000 Tahoe LS used from a dealer in 2001 with 40K miles and understood that the brake pads were still good and had not been replaced. Over the years I have put 175K miles on the vehicle, have been through 4 sets of tires and several electric window motors/regulators, but have NEVER changed the brake pads . . . until today.
I heard the unmistakable high-pitched sound of my rear brakes nearing their end and purchased new pads, rotors, and E brake shoes (which has never worked from day 1). Well, as you can see from the photo, I was about one day away from metal-on-metal regarding the rear pads (after 175K miles, mind you!) and the brake shoes had worn into the hub, causing me to need new rotors as well. BUT, when I looked at the front pads I was dumbfounded. If they continue to wear at this rate, I'll have over 300K miles on my front brake pads and rotor. The engine will wear out before my front brake pads!
Has anyone ever seen anything like this before? Is this some sort of world record? Crazy.
Check out the pics at TahoeYukonForum.com
