Hardin Thicke
- Jan 17, 2007
I was in my dealership purchasing a case of filters, when I commented on how small the PF48 filter was for the size of the engine. The parts guy went away, came back and dropped a PF61 filter on the counter. "I didn't give this to you, but this one is bigger and is the exact diameter, and thread size." I purchased 2 of them to try out. The correct filter, the PF48 has a spring at the bottom of the can while the PF61 does not. I believe this is the anti drainback valve. My thinking is that since the filter is vertically mounted, the drain-back valve is not needed. Any comments or advice?
