karr95
I did an oil change on my Tahoe over the weekend. Since its a 5.7, I assume that it takes 5 quarts, is this correct? When I drained the oil that was in the truck it was at least 6 quarts in there. Did the previous owner overflow it a bit?
BTW, the oil filter was a real pain in the neck to get off. In addition, once you do get it off, the oil drains right onto the front driveshaft linkage. Next time I do an oil change I will try to squeeze a funnel in there or something.
