Gordo
can anyone tell my why the oil screw underneath the truck wont come off Im trying to give my truck a tune up and its just not cooperating any tips? anyone?
You mean your drain plug? There's no reason it should not come off.
Maybe the rubber washer's gone and the screw has stuck to the oil pan.
It may just take a little more pull than normal with the socket wrench. In the past I've had to tighten screws a little more to break the gunk off the threads. I've never run into this with the drain plug though. I'm not sure if liquid wrench would work on the bolt since it's a vertical application.
You might even try using a length of metal pipe on then end of the wrench to get more leverage. I would not say never, because freak things happen... but I don't think you're going to break that bolt applying more pressure to it.
Worst case, take your oil & filter to an oil change shop and get them to put it in for you. Find one of the Cheeeeeeeap places. They might cut you a deal.
BH
