Well, I've never had this issue before. Turn the key and starter kicks on to shortly start the engine. Well, recently, about 1 out of every 4 times, you turn the key and the starter kicks on and just keeps doing it's thing like you were holding the key in the starting posision. However, if you release the key back off of the started position, the starter stays cranking instead of stopping. You have to remove the key completely back to swuare 1 to turn the starter off. Interestingly, when the starter is doing it's own thing uncontrollable, it will never start the engine.
Right now it's more of an annoyance but I don't know if it's doing damage to the starter leading for itto go bad a inconvenient time. Any thoughts?
