1995whitelt
Anytime I let my tahoe sit for more than a few hours it takes a good 2-3 key turns for it to start. Once it's warm it and you shut it off and then start it again she cranks right up on the first turn of the key? I also have a muffler issue, its basically fallen apart. I have a brand new force 2 catback, cap, rotor, new plugs wires, and sea foam ready to see if that helps. It has also started missing slightly at higher rpms. I am hoping this is all connected. I changed the plugs some time back and its had a valve job done about 5k ago with new heads I asumed they changed the rotor cap and wires cant tell really. No check engine light has came on though.
