tbi tpi swap
low94
Hello Everybody This Is My First Post And Was Wandering If I Could Get Some Help/ Info
I Have A 1994 Chevy Tahoe 2 Door With A Bell Teck Lowering Kit And 20 Inch Rims Has About 200,000 Miles On It And Is Getting Tired So I Would Like Too Install A Tpi Motor Are There Any Issues Or Problems That I Need To Look Out For In Doing The Swap .
Thanks Jamie
Low94
Welcome! Should be a fairly straight forward swap. You'll need the computer, and using the tpi harness will make the swap easier. If you don't already have the motor, look for a later tpi system, like 90-up with the speed density maf. I'd also swap the pump for a newer, higher volume pump while you're at it.
