wolfpack1298
- Feb 7, 2008
I have a Sirius ready aftermarket Eclipse Navigation receiver in my 07 Tahoe and I would like to use the factory XM antenna with the Sirius tuner instead of installing a second antenna on the vehicle. I have found several posts on the web where people have used their factory antennas by using an antenna adapter that plugs into the Sirius tuner.
I know that I need the following Sirius equipment to make things work, but I also need an antenna adapter that will allow me plug my factory installed XM antenna into the SC-C1 tuner listed below. I have read that the factory XM antennas are either single or dual lead, but I have no idea which type is installed on the O7 Tahoe's. I have searched around to try and find an adapter, but I haven't had any luck. A lot of the links I found were dead or referenced Ebay sales that have since expired.
Has anyone used their factory XM antenna for their Sirius radio and if so, did you need an adatper for the antenna and where did you get yours if the adapter was required?
Here are the Sirius components that I know I need. The antenna adapter would allow me to eliminate the Sirius roof mounted antenna pictured in the second link below.
Eclipse ECL-SC1 Sirius Satellite Interface:
http://www.eclipse-web.com/acce/ecl-sc1.html
Sirius SC-C1 Unversal SiriusConnect Tuner:
http://www.crutchfield.com/S-d2ob0sVPNRN/App/Product/Item/Main.aspx?I=607SCC1
Thanks for your help!!
