What size torx wrench needed to remove 05 tahoe door panel?
road1will
Norcross, Georgia
After getting my head unit installed yesterday I am installing new speakers in the truck today. I ran into one problem though - the torx screw in the front door panels.
Does anyone know what size it is offhand? I'll run to the store later to try and find what I need but figured i'd check here in case anyone knows...
oomindwarpoo
CA
I don't know the size.. but you can't buy just one torx bit screwdriver, they usually come in a set.
My set was 9.99 and has 40 interchangeable bits with 6 torx bit sizes in it.. Walmart for the win!!!
RenegadeTahoe
You actually CAN buy a Torx driver separate, they're just hard to find. I'd still go with what he said... the set will do you well. ;)
Unless the screws have been replaced before with something different, the screws should be 7mm hex, not torx (you can also use 9/32). If it was replaced, then a screw that size will probably range anywhere from t-15 to t-25, more likely a t-20.
road1will
Norcross, Georgia
Yep, i figured out what it was about 20 minutes after my original post. It was a T-20 and was the original hardware.
Just curious, but what screw was it exactly that you had to remove that was a torx? I probably work on 10-15 of these model trucks a week since the day they came out and have never had to remove a torx screw to remove the door panel, front or rear.
WrenchGuy
Yeah no kidding I was like a 7mm.
Hmm? I bought mine used and some ******* was in them panels before...lol
oomindwarpoo
CA
I sit corrected. Ha!
The stock air box requires torx biit, realized that when i switched my filter. Whole reason I had to go buy some.
