Bowtie4Life
- Oct 13, 2013
I've run into a tricky situation. I clean out the throttle body on the Tahoe and after I put everything back together the car would not start. It's an 07 with a 5.3L. The fuel pump primes and I have pressure, battery is good, I can bump the starter manually so it's not security related. The car won't crank over at all, the remote won't work, the doors locks don't work either.
I talked to a buddy of mine that is a locksmith and he is stumped as well. He told me to cycle the key for 10 minutes 3 times to reset the security. Problem is the security light does not turn on. The gauges don't move right, the interior lights don't work but the dash lights up when you turn the key on. All fuses are good, all relays are working. I'm just stumpt, any suggestions?
