98_2DR
- May 23, 2013
Hello guys.. I need some help!
I have a 98 2 door Tahoe that recently contracted a steering problem.. I was driving it one day and it was working fine, no whines or anything. I pulled into an AutoZone to get a can of Freon for the ac as it needed to be charged. the parking lot did have a steep grade on the spot I parked, I turned into the spot turned off the truck and went inside.. came out started and filled the ac up and when it was blowing cold I got in to complete my errands. when I pulled out of the spot it was ok until I started to turn the wheels to go straight, it was as if my pump had gone out the steering was super tight and it took a lot of effort to steer it. I am driving my daily driver now and looking to get it fixed soon. I have always had some warning in the past when my ps pump went out this was working great turned off and back on and t was out. I checked the fluid level and it was low but not low enough to cause problems, I topped it off and still no change. I raised the front of the truck and went full lock left and right with no change. the fluid did spew out of the cap when I was turning it left to right.. topped off again and lowered back down with no change. I am not sure if there is a test I can do to it to determine if the problem is in the pump or the steering box.. what do you guys think?
