2004 Chevy Tahoe Z71 Overheating Still
cowboymdr
This is driving me, and several techs I know, crazy! My Tahoe started losing coolant at about 1/2 gallon every two days with no visible leaks.
  • Tested pressure on cooling system and found no loss.
  • Put StopLeak into system and saw no change in overheating problem.
  • Flushed radiator and saw no change.
  • Checked input/output temps on radiator and they were normal.
  • Replaced water pump and t-stat, and found water pump was leaking behind the face plate. This solved the leaking coolant problem; however, the truck continues to overheat.
  • If I keep the heater on full @ 90 degrees, temp stays normal all day, but if I turn heat off the truck overheats again.
  • Block test shows no combustion gasses in cooling system.
  • Checked plugs and no fouling or suspicions here.
  • Seems to run at normal temp for long periods, but overheats again everytime I go up a hill.
I appreciate any ideas or insight...I am baffled.
Plugged up Cat?
Plugged up radiator?
Collapsed hose?
cowboymdr
Plugged radiator was the culprit. Thank you for your reply, lesterl.
No problem, sounds like you tried alot of stuff to begin with.... :-)
Murdock927
Hey I have. 2004 suburban z71 and having the same issue new converters water pump went through 2 in one year be thermostat new clutch fan did notice a cold spot on the lower driver side of radiator. No foam in oil no smoke no leaks
tahoesteve666
How did you notice the cold spot? I'd like to know the method/approach for future reference.
