Hi All,
I'm new to this forum and would greatly appreciate some help/advice.
When my '08 Tahoe LTZ is in 2wd and I turn my selector dial to 4wd hi, I can hear the transfer case motor make a quick noise like it's trying to turn but it definitely does not engage. The selector dial switch light for 4wd blinks and goes back to a steady light in 2wd. I then also get a message in the driver info center that states "Service 4 Wheel Drive".
I had it scanned for codes and it came up as "C0321 Transfer Case Lock Circuit Malfunction." Once I clear the code I can get the transfer case motor to make that quick noise again but while the code is still in memory and I turn the selector dial to 4wd, I get no noise from the TC motor, and just get the blinking light on 4wd and it goes back to 2wd.
Do you think it is the Transfer Case Control Module, or the Transfer Case Motor, or what?? I'm not sure what to try or where to start but I'm willing to give it a shot if I have an idea where is best to start.
Thanks for your suggestions and help!!
