I have a 2012 tahoe 4wd with 27,000 miles. There is a vibration in the left front. I checked the wheel bearings, they appear to be tight with no play. I also installed new brake pads and rotors. The noise still presists. The noise is most prevalent at low speed (15 to 25mph) and increases in intensity while steering around a curve . I had it into the dealer, they said there is nothing wrong, however the noise was not always present. It started at approximately 23,000 miles. I was thinking possible CV joint, however after visual inspection and manual rotation of the wheel hub there is nothing that stands out. Any suggestions? Anyone else having the same issue?
Thank you
Thank you
