You can fit 285s stock or you might have to crank your torsion bars a little but mosly likely not. If you do a 3" bl you could go a little bigger 305s. I am running 285 on mine and have no rubbing issues but i cranked the torsion bars a little to level it out.
I only cranked them about 1 to 1.5 inches. I really did not notice that much difference in the ride and I did not get new shocks.95Tahoe said:when you cranked your torsion bars did you see an effect in the ride, or did you get new front shocks. how much did you crank your bars up.
thanks, Nathan![]()
You should not have any problems fitting 285 now.loctite said:yes it's a 4 wheel drive (4 door)
