MO Viet Vet
From another forum: Tahoe/Yukon Forum 99 Tahoe with fuel pump problems
"was driving on the long island expressway today at about 65 mph and my fuel pump quit (i think. but i will get to that) i pull off and go to check the fuel pressure. i don't have a gauge so i just poke the schrader valve by the firewall to see if fuel comes out. it just dribbles out with no pressure. so i tow the truck home ( with a Nissan altima. that was a white knuckle ride!) and drop the tank and swap out the pump. fast forward 3 hours later the truck drops dead again. same issue no pressure in the fuel line. it is extremely cold and im thinking this may be a factor? basically im wondering if their is any reason that this would happen again the same day. could it be the cold? some other problem? or do i just have the worst luck in the world."
Told him to get pressure readings and be aware of injector bleed off and maybe fuel relay problems.
"thanks for the wisdom im going to check the pressure and verify its good (or bad) and verify that i have proper ignition function. also another note when i did the schrader test it was with the pump on (key in the run positon) im not sure if that makes a difference"
Told him it did make a difference but still need pressure readings.
"Yep both times it died i tested it with the key in the run position. my assumpion was with the key on it should have hAd 60psi when i opened it up but both times it was almost nothing
---------- Post added at 12:11 AM ---------- Previous post was at 12:09 AM ----------
it wont even start so checking it when it stalls again isnt an option.
---------- Post added at 12:12 AM ---------- Previous post was at 12:11 AM ----------
im still going to get a pressure gauge on it but im positive the reading is going to be 0
---------- Post added at 12:14 AM ---------- Previous post was at 12:12 AM ----------
im thinking maybe i have crustys in my gas tank that is killing these pumps. when i did the first pump the sock had some nasty stuff wedged in it"
Then he installed another pump.
"the fuel pressure is 35 psi while cranking and when the key is first put in the on postion. its on the third fuel pump. every time a new one is installed it runs but shortly after it dies. i am at a loss."
That would have to be the worst inside tank problem I have ever seen. Any ideas?
