98_2DR
- May 23, 2013
Sorry for the several questions I am about to ask but I need some direction and I'd rather ask all at once than be a post whore.. I hope I describe everything well, if not just ask..
1. I replaced my thermostat today and the temp theme gauge still hovers around the bold line in between 100 and 210, I have replaced the cluster with a spare I picked up and same issue so it's not the gauge is this normal for the tahoes or could the temp sensor be bad?
2. I just had dual exhaust added Monday, it's borla brand and they "dumped" the pipes right at the rear axel. Since then when you rev it up,it sounds great when you open it up on highway it sounds like a NASCAR, however when you let off the throttle it sounds like crap, almost like an exhaust leak. Took it to autozone and another shop and they told me its normal when you have dual exhaust because "your hearing both sides of the engine separately"... Sounded like crap to me but I know nothing about exhaust systems. I took it to another muffler shop and they said don't worry about it, so I took my new knowledge and my Tahoe back to the shop who installed it said the mufflers are good, and he showed me with a dollar bill where one muffler in "blowing" and one was "sucking".... He put the truck on a ob2 scanner and no codes were being thrown or even pending, he did say it sounded funny but only thought it may be a leaky intake manifold gasket, a bad exhaust valve, or a ton of built up carbon... Any ideas????
