aznpersuasion
- Sep 25, 2012
it started randomly, if i hit a bump the ABS light would trigger. if i turned the steering full left and brake the pedal would modulate and ABS light would trigger. now as soon as i brake after starting the truck the pedal will modulate and ABS light will trigger. after the ABS light triggers and pedal modulates it will continue you operate normally as if nothing was wrong (however i have never needed to panic brake yet). thoughts? sensor? fluid is full
